SyTyAddict
Turbo S10's FTW!
- Oct 8, 2011
I have this posted over on SyTy.net and I thought it would post it here also. I'm looking to sell my Sy, I've realized I don't need two of them at this point in my life. It has 102,6xx miles, I have owned it for about 4 years and it has always been reliable and fun to drive. Everything works including: power windows, power locks, heat, and a/c. It has no rust, besides the usual light surface rust on the frame and axle, there is none on any of the sheet metal or under any of the cladding. It's in all around great shape, runs flawlessly, no blowby smoke from the oil fill cap, doesn't use any oil, and still shifts very firm. It does have the typical puff of smoke when it is cranked, if it has sat for a while. It does have a rebuilt title from a collision in the left front.
Modifications and replaced parts:
-new Sumitomo HTR tires all the way around
-Gilbert HD front driveshaft
-block mounted oil filter
-ABS delete
-solid motor mounts with polyurethane trans mount
-B&M 29k GVWR transmission cooler
-remote spin-on transmission filter
-polyurethane front differential bushings
-new viscous coupler in transfer case
-cold air intake with 10" K&N cone filter
-muffler-less catback exhaust
-Shurflo intercooler pump
-metal intercooler lines replaced with 3/4" heater hose
-new brake pads and shoes
-new rear axle seals
-ZQ8 quick ratio steering box
-jeep steering shaft upgrade
-Bilstein rear shocks replaced within last 2k miles
-heat exchanger debris screen
-Sportmachines reproduction OEM style decal set included (not installed)
SOLD!
-ABS delete
SOLD!
