complete cluster, snaps right in. yes, the BIG peice that goes over the A/C vent, headlight, dimmer, defrost switches
matching ultra lite tach included!!! small sport comp tach not included
just add BOOST gauge...
2 5/8" pro comp ultra lite water oil volt
electric w/ sending units
lights were water temp warning, oil temp warning, and turn signals
fuel gauge mounted in headliner trim is GM 0-90 and is LUNAR 2"
have matching 3 3/8" tach:
it's an in dash BUT i have the THICK mounting bracket for it. it'll fit nince n snug on lower a pillar.
shift light has had the wires extended for the pills to be remotely mounted (glove box) wire length does not effect resistence and light comes on at exact RPM
if you don't mind tossing the speedo, this setup isn't half bad.
it was in my bracket car until i sold it.
make offer.
make offer.
