Just take the cover off and put on a new gasket and use RTV...check to make sure the flange is flat in that area if not you might have to get a flat head hammer, like a tack hammer and flatten that one section over a piece of flat steel like the flat spot on a vise.. You could even use a small head of a flat head bolt and a regular hammer to do this .. then put a straight edge up against the flange to make sure it is flat... yes I know it is a lot of work just to get this thing off the motor but you have no choice..
