OK, everything has been put back together and I took it in for an alignment. The shop advised he could not do anything about the negative camber as he removed all of the shims on one side and it still is off. He said the upper control arms need to be a little longer to correct the camber? I have attached the spec sheet with the alignment. Its all greek to me but it appears everything is off. Are these specs within reason for what I have replaced or do I need to go someplace else for the alignment? I replaced both upper (gbodyparts) and lower control arms (UMI)
View attachment 237975 with standard balljoints and all of the tie rods, center link, idler arm, swaybar endlinks etc.
