Front Cam bearing clocking 109 block
reggie0704
Does it matter which way is clocked .
Put in new front Cam bearing. And noticed it's clocked at 4 oclock
H.P. bearings have a groove on the back side to help oil flow to the drivers side lifter galley. I port the factory groove in the block, along with all of the other galleys before assembly. This eliminates the " clicky comp" syndrome.
The small crossover groove must supply all of the oil to the rocker shafts, rocker arms, and what ever oil leaks between the lifter body and the lifter bore.
TIMINATOR
