redhotrod Turbo Happy Joined Nov 19, 2002 Mar 9, 2014 #1 Will the output shaft turn in reverse by hand before fluid is poured in the pan? 2004R is in question.
M mikestertwo Well-Known Member Joined Sep 13, 2006 Mar 10, 2014 #2 redhotrod said: Will the output shaft turn in reverse by hand before fluid is poured in the pan? 2004R is in question. Click to expand... Not easily.
7 77 cruiser Well-Known Member Joined May 24, 2001 Mar 11, 2014 #3 If it can't be turned the band could be too tight. Take the snap ring off of the cover of the servo & try it.
redhotrod Turbo Happy Joined Nov 19, 2002 Mar 18, 2014 #4 Thanks, everything works fine, It would turn when I put some muscle on the tires in reverse rotation
