Frame needed
I have at least one very good one or two? between $200 and $390 depending on condition located in Worcester Ma #774 696 3585 THANX KERRY
i have at least 5 frames here in connecticut.i'll let you have the any one you want $300 .i have a super nice 1 from a 65,000 mile car.there is not even any scale on it. kid pulled car apart to make a racecar he did not get past stripping car apart. i am sure you won't be disappointed
meriden connecticut 203 213 9126
tons more parts as well parting a gn and 5 regals and a 87 t type and some other g bodys
http://www.turbobuick.com/forums/parts-sale/279154-87-turbo-t-parting-out-connecticut.html
http://www.turbobuick.com/forums/parts-sale/277304-parting-out-gn.html
http://www.turbobuick.com/forums/parts-sale/271260-4-na-regals-getting-parted-out.html
i don't have exact pictures of the frame i am talking about but the cutlass that is a rosewood color is the 1 i am telling you about the frame from.currently the car is about 100% apart just need to unbolt the 10 bolts that hold body to the frame that is it . car is way apart,the only hole in this car was a small 1 behind 1 tire.this car even had really nice doors that is why i bought it.i sold 5 frames last year.i had people here from mass,new hampshire,new jersey and upstate new york and none were disappointed all went home happy.i have some pics of other frames that i sold but nothing i was telling you about.give me a call 203 213 9126
connecticut doesn't use salt on their roads i believe mass and other more northern states do.we just use sand and it helps the frames last longer.
i have had rotted frames but more tend to be good than not
http://i305.photobucket.com/albums/nn217/ttaowner/CUTLASS442/garage2gs062.jpg
i got 1 of the 2 frames out from under car last night looked really good. the
2nd frame could be pulled out from under car within a hour probably try to get that 1 out over the weekend,
you can pick up a frame and haul it home with a pickup truck with a ladder rack or use a car trailer or worse case scenario rent a truck from uhaul
203 213 9126
Still Looking ? I Have Frame #2 Coming Out Tomorrow Night So I Will Have 2 For Viewing.
Give Me A Update As I Would Like To Give A Fellow A Board Member
1st Shot Before They Are Advertsied Elsewhere.
203 213 9126
Frame
Guys.. Make Sure The Frame Is From A Turbo Car, The Trans Crossmember Mounts Differetly. A Non Turbo Car,you Will Need To Weld The Lt Side Bracket Onto The Frame To Hold The Center Crossmember.. The Rt Rear Exhaust Hanger Mounts Differenly(just Drille 2 Holes) Other Than That,the Frames Are The Same...
YES 1 OF THE 2 IS FROM A GRAND NATIONAL!
2ND FRAME IS FROM A CUTLASS AND THAT 1 WAS PULLED OUT TODAY AND ALSO READY TO GO !
I THINK IF ANY OF THESE G BODYS HAVE THE 200R4 IN IT THE WILL HAVE THE BRACKET YOU ARE TALKING ABOUT. EITHER WAY THAT IS A EASY FIX COMPARED TO ROTTED FRAME RAILS THAT ARE COMMON HERE IN THE NORTHEAST
203 213 9126
