next_level
- Jan 29, 2002
i posted a while back when i got the car about this wierd ticking noise...i went through everything that everybody suggested (without pulling the motor) all the normal stuff, downpipe, converter, flywheel, lifters, blah blah blah...well i ended up pulling the motor the other day...and lucky me, i cracked a piston....i dont have the motor torn down yet, but from having the pan off it just looks like the skirt cracked off...and that was slappin around in my pan, doesnt look like it did any other damage....cylinder wall doesnt even look bad from the bottom...it did take a knick outta my crank where it was drilled from balancing, so hopefully that can be repaired....
just though i post it up for all you guys searchin for that noise...sometimes it's not a common problem
