This a nice driver,not a garage queen.
87 GN 123,xxxk fresh standard motor 2-08,about 3k on it now.
standard crank,std bore,stock heads,204/214 cam.
stock turbo
stock IC
30 lb injectors,TT chip
stock downpipe,aftermarket exhaust(older hooker system?or dynomax)
3.42 posi
ran 13.10 on 16lbs of boost on street tires on it's only trip to the track.
has new bodyfillers front and rear. new weatherstrips door and roof rail(aftermarket).
Interior is an 8,it's clean and in good shape
body is a 7,decent paint,shines would new repait to be perfect,nice for a driver. Small rust spot in corner of driver door. No rust in floor pan,quarters,rockers.
Engine bay,trunk are detailed,floor pan was cleaned,painted nice carpet installed.
Small rip in drivers seat.
Cold AC with 134a retro,new accumulator,orfice tube,good compressor.
New upper and lower balljoints
new upper control arm bushings
new fbody radaitor
trans cooler
new belts and all hoses
new alt
new crank sensor
new cam sensor
aftermarket guages
will need front tires soon.
current VA inspection
Latest additions 11/2008
Rebuilt trans
ck shift kit
10 vein pump
wide band
correct BRF valvebody,governor
BRF servo
New clutches,steels,bushings,thrust washers
trans is solid mid 11sec capable.
Correct D5 convertor
No flares,no leaks
new 340 pump
hotwire kit
powerplate
Price is $10,500 cash only. No trades
cell 757 560 2782
email sasybit@ymail.com
price will change in the spring and combo may as well.
stock turbo
stock IC
3.42 posi
new fbody radaitor
trans cooler
new alt
new crank sensor
new cam sensor
aftermarket guages
Rebuilt trans
ck shift kit
10 vein pump
wide band
BRF servo
No flares,no leaks
new 340 pump
hotwire kit
powerplate
cell 757 560 2782
