FMIC X2 pumper
I have a double pumper here that was removed from a customer's GN that is going back to stock.
It only has one pump, as he used the other one. The wiring, hobbs switch, relay and wiring are with it.
Do not know how much he want for it, but make a offer so I can get it off my shelf!
Soldier I have a dp setup which I believe is an atr dp with the Reds wire for the second pump. The pumps are the gss242 which is the 190lph sending unit is 90ohm the wires have been exposed not sure how, but you can see in the pics, prob needs to be fixed at the connector $250
Turbognx...think im going to pass on that unit. Think i found what i was looking for. Appreciate it.
