Made my first concerted effort to tune my car. In addition to my sig at the bottom the car was set at 15# boost and pump gas(fuel press 45 static). My direct scan gave me the following readings at wot:
tps - 3.06 max (shouldn't this be more?)
02 - 761
xcount - 225
iac - 61
kr - 0
knock count - 1
spark adv - 27.4* max
my pit bull chip calls for adv of 26* @ 2000rpm
the numbers above occured early in the run where the tps reading was at its max. Should'nt the tps voltage stay the same at wot throughout the duration of the run?
please help me interpret this and make some suggestions on improvement. I trust you guys with this, so any suggestions or questions will be answered. thanks guys!
02 - 761
xcount - 225
iac - 61
kr - 0
knock count - 1
