Hello everybody,
I´m new here on this forum. My name is Juergen and I´m a 24 year old guy form Germany/Europe.
I´m restoring a 72 Chevelle Malibu right now and I decided to put in a 383 Stroker engine with about 450hp, a 3.73 eaton posi differencial and a th2004r.
I bouhgt the tranny and now I want to rebuild it and make it strong enough for my engine.
I got a lot of informations from this site and from bruces´ site, but at least I have some problems to figure out which parts I should use to rebuild my tranny.
I never opened a tranny yet and I don´t really know what parts are in there and how they were called so it´s a little difficult to take the correct parts.
My car should become a daily driver.
I hope I get a little help rom you.
1) Bruce says that hot temperature kills the trannys. I know that, but if I take the sheet metal aluminium pan, wouldn´t the oil stay too cool, or lasts very long to reach the right temperature?
2) I know, I´ll need a shift kit, but I guess there are different shift kits available. And I found just one on the ptsextreme.com site. I´ll need a shift kit that doesn´t shift too hard, because I need/want some comfort in my car because it´ll be mostly driven on the road and not on the strip. Will the shift kit from Bruce be the right one for my car?
3) I guess the stock case and the stock output shaft will be good for my car, right?
4) PTS installs a Torrington low drag bearing for the Park Gear. I guess it is called PTS Xtreme Roller Park Gear. Would this be a good thing to buy for me? I want to be sure I have a tranny that is strong enough and "long livin". I don´t want to rebuild it every year.
5) Low/Reverse clutches: What clutches should I use?
6)Bruce suggests a new roler clutch for the low planet, but I didn´t find one on his site. What part is that?
7)I guess the roller bearing in the low/reverse center support is the way I have to go, but I didn´t find the part on pts?
8) I read I´ll have to drill out lube holes to increase lube to bearing and pinions of the front planet, but where exactly I have to do this?
9) Will I have anything to do with my forward drum? I don´t know what time I´ll make with this engine/tranny/differencial combination, so I don´t know, how I should go on.
10) For the direct drum it´s good to use Teflon Rings, and Alto Red Eagle clutches with my setup, right?
11)Bands and related: I guess the Red Alto Band would be the right for me with the 300m anchor pin?
12) I guess a modified GN servo will work well in my tranny. I´ll just have to make the apply pin adjustable, right?
13)What exactly I have to do with the center support? Just teflon ring everything, or will I have to do more?
14) The OD should be strong enough for my car, right?
15) A 3 clutch piston should be used and Alto Red Eagle clutches. What parts are this at pts?
16) OR clutch will be fine if I use any stock clutch, right?
17)The Overdrive Planets are know for cracking the splined piece and stripping the splines. This could be a problem for my car, too. So will the Billet splined OD planet from pts solve this problem?
18) The input shaft seems to be a weak point, too. But I guess it should be good for my 450hp engine. Is it enough, if I just use teflon rings?
19) When I read, what Bruce wrote about the pump, I have to order a new one and modify it? I also should install a hardened stator. Will I need new boost valves? And if yes, what size?
20) The governor should be pinned in.
Oh man, I didn´t know it will need this much work to get a tranny that´s strong enough.
Can anyone help me with the parts I need, because when I read the pts site I see a lot of parts, but I don´t know what parts I really need.
Thank you very much.
Regards
Juergen S
Regards
Juergen S
