Rowdy45466
- Sep 25, 2006
Hey,
I'm thrilled to be a 1st time GN owner. The car is OK. Showing its wear and tear and has had a poor-average paint job done on it. Looks OK from 10 ft. Has a bunch of perfromance up-grades.
Motor looks to have been rebuilt with upgrades including Hooker Super Comp headers,high flow crossover, a 3" downpipe,test pipe w/dump,3" dual muffler exhaust,adjustable waste gate rod,ESP front mount intercooler ($1063 new) torque strap,B&M linelock,2004R w/Trans Go shift kit and billet servo (shifts very well) 9.5" 3500 stall,SFI flexplate.Factory 3.42 posi rear.
.Interior is in decent shape, but needs the following: Driver seat needs a new cover, power seat does not work as do not the power door locks. A/C still works and windows are fine,but the passenger window switch only puts the window up not down. I believe it just needs a new switch on the passenger,since you can put the window down by the switch on the drivers side, passenger door panel has speakers in it and the driver side does not,so I may need to get a passenger side door panel.There are also boost,oil pressure and temp gauges mounted on the dash.
I was told most of the above and I'll have to verify lots of it. The PROM chip and it is an aftermarket chip labled Street 93 20* 40 # What does this mean? How do you tune it and with what?
What do you think it needs? Are there any after market places that have a good catalog to use to find what I need?
Good internet sources?
Thanks,
Rob
Thanks,
Rob
