1986 T-top Buick Grand National 64922km (40341 miles)
Weber short block 245ci, M&A heads, erson 214/214 flat tappet cam, pt67/76 dbb turbo (.63 ar) , 70 mm accufab TB and Plenum, PTC convertor, 275/60/15 MT drag radials, 3700lbs race weight, roller rockers, port match lower intake , razor dual alky injection set at 8 (max), 94 octane, hooker cat back with dyno max ultra flow muffers, kenne bell headers, 80 lbs injectors, turbo tweak alky chip with 23/21 timing, with a gen 2 with a LS1 maf ,thdp, mease 24 row IC, PTC 3200 stall 9 1/2 convertor, Ron Custom max boost brake module, rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, Weld Drag Lites with skinnies up front, electric exhaust, hr rear sway bar, no front sway bar, 90/10 lakewood in the front and 50/50 lakewood shocks in the rear with energy suspension poly bushings all over, boxed rear lower control arms, Big mouth cold air with an AFE air filter.
Exhaust opened (25lbs of boost)
60FT=1.55 (foot brake on 2 lbs of boost)
1/8= 6.76 at 103.56 mph
1/4= 10.53
MPH=130
Wide Band=10.2 to 10.3 top of third.
60FT=1.45 (foot brake on 5 lbs of boost)
1/8= 6.64 at 103.38 mph
1/4= 10.45
MPH= 129
Wide Band= 11.0 to 11.1 top of third, took out to much fuel on that run .
I didn't get a chance to play with it a bit more because I blew a driver's side header gasket (felpro 1400) on my third pass.
Marco.
1/4= 10.53
MPH=130
1/4= 10.45
MPH= 129
Marco.
