ok here's some first time numbers from my car:
while cruising at 2250RPM's
BLM= 113
MAF= 28-31
o2's= swing from 31 to 672(lowest and highest numbers shown)
IAC= 33 13%
I took her on the highway and got interesting results:
when I reached 3500 RPM's in 2nd gear
BLM= 120
MAF= 137
o2's= still swinging away(the frame I hit 3500rpm o2 was at 102
IAC= 33 13%
I eased a little on the throttle to let her shift into 3rd and then got the boost to 12-13psi when this happened:
at 3025rpm I hit
BLM= 120
MAF= 148
o2's= 0
spark ret= 8.8 deg
my o2's stayed VERY VERY LOW for quite some time. between 0 and 4 mv for quite a few frames. at one point with a BLM at 128, o2's at 4mv MAF at 7(I let off the throttle) I hit a spark retard number of 12.7 deg.
these are the numbers I thought were the most interesting I'd say that crusing around I averaged a BLM of 113, MAF of 30, o2 swung from 150 to 650(average lows and highs) with an average engine speed of 2250 rpms.
where do I go from here?
thanks
-Brad-
BLM= 113
MAF= 28-31
IAC= 33 13%
BLM= 120
MAF= 137
IAC= 33 13%
at 3025rpm I hit
BLM= 120
MAF= 148
o2's= 0
spark ret= 8.8 deg
thanks
-Brad-
