Maybe I am retarded, but I can't get the charging system to work properly on the 87 TR in my signature.
The factory alternator was bad, I purchased an LT1 impala alternator on the recommendation of turbobuicks.com.
I still had no charge, and I discovered that that the small wire that clips into the back of the alternator had no voltage. Again, on the advice of turbobuicks.com I bought a field fix harness from Caspers Electronics.
The car seemed to run OK now, but the battery would die in just a few hours if the car was left sitting. I discovered, again through turbobuicks.com, that the alternator was pulling 12V the entire time. Even with the car off. I took the LT1 alternator back to the store and had it replaced under warranty.
I installed the new alternator, and everything seemed fine. The new alternator did not pull any voltage with the car off. After 2 days, the battery was dead again. I jump started the car and checked for voltage at the alternator with the car running. The big post on the back of the alternator was dead. Zero volts. I removed the alternator and went to the local AutoZone where the alternator tested good, producing the required 14.4 volts or so. I came back to the car and reinstalled the alternator. I put a battery charger on the battery and started the car. Again, the big post on the back of the alternator was dead, no voltage. I pulled the field fix harness off the alternator and tested for Voltage at the 2 of the 4 sockets that contained pins. For simplicities sake we will number the sockets 1 threw 4. Socket number one was the largest of the sockets and was empty. Sockets 2 through 4 are the same size, and socket 2 and 3 contain pins. Socket 2 had 12V and socket 3 was dead.
Looking at the 4 sockets on the on stock connector, only socket 3 contains a pin, so the way I see it pin #3 has to be the pin that the alternator needs to see voltage at in order to charge. I called Casper's and John confirmed that the LT1 alternator did require a different plug. I again started the car and ran a 12V jumper wire to each of the pins in the back of the alternator and checked for voltage. On pin #3 the alternator finally produced the requisite 14V. The field fix harness was suppling power to the wrong pin in order for the alternator to charge. I took the alternator end of the field fix harness apart and swapped sockets 2 and 3. Now, the alternator would see power at pin #3 instead of pin #2. The car ran fine for 2 days.
This morning, the battery was dead again. I started the car with the battery charger again and started to check things. With the large cable not attached to the alternator, the alternator is only producing 11 volts.
The way I understand the system is that the field fix harness is supposed to mimic the voltage drop across the dash bulb, and feed the alternator with some voltage that is less than 12V. My field fix harness, which was wired wrong for my LT1 alternator application, is supplying what ever the battery voltage is to the alternator. If I understand things properly, that will destroy the voltage regulator inside the alternator. To me, that sounds like the problem I am having.
What voltage should the clip on connector provide to the LT1 alternator?
Why doesn't my field fix harness limit it to the proper voltage?
Why did everyone tell me to get the LT1 alternator yet no one mentioned the plug was different?
Can the factory alternator operate with the proper sub 12 Volts applied to pin 2 or 3? The way my field fix harness was assembled, it was supplying 12V to pin #2, where the stock connector was applying voltage to pin #3.
Thanks!
Thanks!
