When the AC is turned on the car idles up to 3500 rpm's. What paramaters, in FAST, controls the idle ramp..? Everything else works great.. Suggestions?
Under idle functions.....idle parameters.... there is a AC idle increase (RPM) ...... this is normally where you would set the amount the ECU is supposed to up the idle when the AC kicks on.... What is yours set at?
