Cheeseburger
- Jan 25, 2004
Ok, I got rid of all the factory wiring that i'm not using, Brake/fan relays/cam sensor/crank/oil/coilpack/AC wires etc.
Since this is a race application i wanted to clean up all the wiring, and i also saved a fair bit of weight while i was at it!
Anyways, i get power to the caspers box, (standby and 12v with key on) and the motor cranks but nothing for the xfi (all lights out).
I also have no fuel pump prime now, i have the xfi hotwired and am getting power to the relay.
I'm thinking a ground possibly, i removed the wires and pinout connector's for everything i was not using..
Ground issue for the xfi??
T.I.A.
T.I.A.
