Fast management question????
I have run into a road block with this problem.
My 87 GN has the FAST/sequential on the car for 4 years now.
The car was dialed in last year with only 5-7% of correction in closed loop. The beginning of this year the car started to run very
rich at idle & on accel. I check for vacuum leaks, changed spark plugs, check fuel pressure (same as before) check fuel pressure
regulator, checked to see if injectors leaking down and all are fine
I checked the program and found the reading for UEGOS (V)
in red and reading .44. From all the feedback I received I felt it pointed to my wide band 02 sensor. I ordered a new one with the
software to re-program the new sensor to the ECU. Started the car up and now the reads are as
UEGO (V) .65
UEGOS (V) .51
UEGOR (V) 4.51 and it is highlighted in red.
The car still runs rich and chugs. Does the reading in red mean there is something wrong with the sensor or not? I changed the car into open loop and it is no different. When I try to lean the car out using the VE tables it stumbles and stalls, when I put it back
it just dumps fuel. I'm stuck and need some sound advice from
fellow FAST users please
Its been 4 weeks trying to sort this out and I have to walk away
from the car after hours of trying to figure it out so I don't drive off a cliff.
Guys I'm looking for help badly.
thanks
UEGO (V) .65
UEGOS (V) .51
thanks
