BigBird R/T
- Jun 23, 2005
Can't find IAC POSITION in the dash setup. All I have is IAC D,P,PD and TARGET.
Thanks Norbs, Thanks CMB.
I'll do another log tomorrow when the truck is cold and post the log. By the way it's a supercharged 360 Dakota truck that runs low 7's 1/8ths, low to mid 11's 1/4. It's a fun grocery getter.
Also CMB, with the ccom wp I can only log 14 sensors at a time. You requested 19 but I think I know which are the most important.
Thanks guys.
I'm curious about this also as my car hunts on a cold startup...only does it for about 20 seconds then idles fine...
Here are the .gct and .log files from this evenings start up. Hope it can help. Its not that cold here (85) but in COLD weather it's worse. Thanks..........
No I don't have B2B...have XFI...the hunting only happens on cold start...on warm starts it idles fine...I've tried adjusting the Start IAC Pos vs Coolant Temp table but it didn't help...
CMB, I warmed the engine up this evening and checked the IAC. It was at 37 or so and adjusted the plates to achive the target rpm of 800-850. The IAC was then at 20-21. Opening the plates further only raised the rpms (1200 or so) and would not lower the IAC....? The idle TPS is still about the same (14-15) so left it set at 16. Damn, I feel like I'm learning something.
Anyway, the engine is hot now so will do the cold start logging tomorrow evening with the new gct file (if I get home early). I would take this to PM ing but guess it could be helpful to any new FAST tuners if it's alright with you. I'm going to swallow my pride and admit I'm a newbee even though I've had this system about 5 years now. Thanks.............
Im just passing along knowledge to fellow buick enthusiasts . I too learn new things every day.
Looking foward to seeing the log tomorrow.
