You can get the fan switch (screws into the top of the intake on the driver's side) at any auto parts store. It's $12.00 and up and fits a ton of GM vehicles. It only has on and off (one wire), not high/low for fan speed, so if the fan comes on, it's working. Check your relays/wiring/resistor on fan....Nice T-top BTW
Dude, it sounds like the blower resistor went on the motor. When the resistor goes it usually takes out one or more of the speeds. This is the electrical piece that is right next to the blower. If you want you can try unpluging it to see what changes it makes for you. If you want to replace it, I can try and locate one for you. Hope this helps.
