B BLU Member Joined Mar 26, 2004 May 7, 2005 #1 I had trouble with my fan relay switch. Replaced it and still had problems I removed it ...will this create any problem ?
S sam87 old but still runnin Joined May 25, 2001 May 8, 2005 #2 no problem The switch was probably installed by someone to bypass the relay & run the fan manually. Remove the switch & it's wiring, connect/splice the factory relay wires & fan should run ok - if the relay is good.
