pure_boost
- Jul 15, 2001
I haven't had a chance to get my car to the track this year, but I did a few things to the motor in the spring. Right now, I'm able to run ~19lbs of boost on 93 octane (no alchy) with a few degrees of knock occuring only once in awhile. If I remember correctly, I have the fp set at 43lbs, as recommended for the testa chip. I also have a power plate installed. However, sometimes the scanmaster shows O2 volts down around 760, but other times it's up in the 790's. Should I turn up the fuel pressure or leave it where it's at? Thanks.
