External WG ?
MajorBoost
Can someone post a pic of how they ran the hoses for an turbonetics external WG? I am new to these and want to turn up the boost right now it's on the low side.Which means car is only @ 10lbs have all the hoses and boost bleeder just need to see how to run the hoses run never got instructions, thanks in advance:smile:
You need to run a hose out from the compressor. Put a tee on the end of it. From the tee run one line to the bottom port of the WG. The other end of the tee run a line to the boost bleeder/air regulator then to the top port of the WG. With the bleeder/ air reg closed you will get all boost to bottom port opening up spring in WG very fast hence only having 10 psi. With bleeder on top line opened a little bit some boost now goes to top port and pushes down on spring keeping WG puck sealed longer creating more boost.
Clear as mud?:D
Is there now no need to run a line to the vacuum block? before I had it running straight from the block to the low side, thank again this helps a lot.:smile:
