I just got an egt on my car. I have been tuning with a scanmaster and a Conley knock detector. My chip is an old max-effort set-up for my 50lbers. The timing is set at 18 degrees. My o2 sensor has'nt been changed in a while because the chip is open loop all the time. I am running 45lbs of fuel pressure(line off) AT IDLE. My question is what should my egt's be at idle. I know that at boost they should be at 1550 to 1600 roughly. I am seeing 1800 degrees at 19lbs with 94 octane and xylene. That seems WAY too high, but I am not getting any knock sensor reaction at all. I am not sure the egt is calibrated correctly. I am thinking that there should be a fairly consistant idle temp for all cars if the air/fuel ratio is correct. Any help would be appreciated.
