I'm with Flyin B, did some more research, and it seems that Garrett used 8 mm x 1.25 mm pitch bolts for the exhaust bolt threads. He is also correct about thread engagement. With the 30 mm long bolts and the two lock washers, the thread engagement is minimal. Also, the lock washers no longer have any tension to them, they are flat (heat!).
If you can, dig up some copper based anti-seize. Holds up much better to the heat then aluminum based stuff.
RemoveBeforeFlight
