Even More Miscellaneous and Hard to Find Parts
sumnerw
My three GNs are long gone and I'm finally getting around to selling my inventory of parts that I accumulated.
All parts are new unless stated otherwise. Many of these are no longer available so here's your chance to stock up as I once did.
Used parts are in good condition or better - no junk.
Pg and item number refer to the 1982-1990 44-W Illustration Catalog.
Prices are per piece unless stated otherwise. The number after the price is the quantity available.
Prices do not include shipping and insurance. PM me with your wants and your zip code for a shipping and insurance quote.
I prefer PayPal. Check my eBay feedback (sumnerw) - it is 100%.
All transactions will be on a first paid basis.
Keep an eye out for more listings - I still have a lot of stuff to dig out!
COIL, IGNITION (C3I-TYPE 1) (pg 2-30; item 1) Borg Warner Division E45 $80.00 1
CONTROLLER, ECM - Used; includes CALPAK and BBKJ prom GM #1227148 $80.00 1
Sensor, w/Drive, CM/SH (Camshaft position sensor) (pg 0-43; item 95) - Used GM #25516915 $75.00 1
SENSOR, CR/SHF POSN (pg 0-43; item 78) AC-Delco 213-292 (GM #12537109) $50.00 1
COVER, RH (for locking T-Top; blue, paint to match) (pg 12-241; item 15) GM #20704030 $40.00 1
COVER, LH (for locking T-Top; blue, paint to match) (pg 12-241; item 15) GM #20704031 $40.00 1
SWITCH, W/ESCUTCHEON,F/D ELEC LK CONT (CHROME) AC-Delco D1480D (GM #20734310) $37.50 2
SENSOR, EXH OXYGEN AC-Delco #AFS 20 (GM #25162693) $35.00 1
SPARK PLUG WIRE SET (6 CYL) AC-Delco 616F (GM #12073924) $35.00 1 set
R12 (Freon) 12 oz. Can Arctic-Air $25.00 4
CABLE (pg 9-95; item 11) (for power antenna) AC-Delco 22038195 (GM #22038195) $20.00 1
Boost Gauge; Mechanical; 0 - 30 psi; 2-1/16"; Black face and bezel with white lettering - Used (some paint on bezel has rubbed off) VDO #121-003 $20.00 1
SENSOR, EXH OXYGEN - Used AC-Delco #AFS 20 (GM #25162693) $15.00 1
FILTER, FUEL (TYPE GF481)(3.8-7) (pg 3-20; item 26) AC-Delco GF481 (GM #25055052) $15.00 1
Timing chain tensioner (pg 0-43; item 108) GM #25532546 $10.00 1
Ash Tray Switch Plate - 5 slots - Used Kenne-Bell? $10.00 1
Crankshaft Position Sensor Bracket AC-Delco 213-280 (GM #12537113) $3.50 1
FUEL INJECTOR SEAL KIT (One pintle cap, two o-rings, one spacer) Borg Warner Division 274081 $3.00 14
SEAL KIT , FUEL FEED PIPE FRT & RTN (O-RING SET) Borg Warner Division 27478 (GM #22514722 and 22516256) $3.00 1
SPARKPLUG AC-Delco CR43TS $2.00 6
ALDC Cover GM #10021766 $2.00 2
Timing chain tensioner bolt (pg 0-43; item 107) GM #1356635 $2.00 1
FUEL INJECTOR FUEL INLET BASKET SCREEN $2.00 13
SPARKPLUG AC-Delco R44TS $1.50 6
Timing chain tensioner spring (pg 0-43; item 106) GM #1358909 $1.00 10
CLIP , FUEL INJ - Used GM #25519369 $1.00 16
Fuel Injector Wiring Harness Connector Retainer Clips - Used $1.00 10
The following items are sold:
Coil
Both T-top trim pieces
Both door lock switches
Spark plug wire set
Fuel filter
Ashtray switch plate
Both ALDC cover
Antenna cable
Thanks,
sumnerw
