johnnyttype
- Apr 18, 2007
Alright men! Its been a while since i posted on here but now im gonna need some insight from you guys...
I was on an on ramp today and figured id give the car the ol' boost session... this was a bad idea cause it quickly was followed by a lovely grayish blue plume behind my car! Pulled the car off into a nearby parking lot to see what was wrong. Car was chugging slightly and puked some oil out of both breathers. Nothing real noisey like metal bangin around... but i did happen to notice that i had COMPRESSION coming out of my breathers!!!
Car can still run, not that im going to do that though... NO coolant in the oil, car steady at 167 degrees when it got injured, smokes blue-gray when a lil throttle is given, and when cranked over a fairly noticeable hesitation occurs every revolution...
Im thinkin i either put a hole in a piston or broke a rings??? What do you guys think?
Im pretty sure i will be yanking the engine out pretty soon... Just as i thought life couldnt get much worse... i broke my buick:frown:
thanks
john
thanks
john
