when going with stock uncut heads , uncut block and stock height gaskets stock length rods installed with the shafts torqued to 24ft lbs is usually fine
but when is everything as it was from factory , little things add up
heads milled , block decked
so whenever redoing its always best to check first
with heads and headgaskets installed and torqued
install cam and timing set
install a lifter and set cam to base lobe ,
using an adjustable pushrod check tool screw it down so its a little shorter than the rods you think will fit
..drop it in and install and torque down the rocker assembly
adjust the tool to zero lash
then remove rockers and remove pushrod check tool and turn out an additional 3/4 turn for the preload (1 turn =.050" and your target is about .030") , compare the tool to the pushrods you have
you should also check at rear of that head and front and rear of the other head to ensure there arent any major differences---
if the tool and what pushrods you have are the same then use the rods you have
install them and bolt the shafts down to 24lb/ft
if they arent the same its time to order new pushrods, you can usually send the tool to the manufacturer and theyll build your pushrods to the same as the tool
