Engine Parts
TurboTerry87gn/Buick GN parts for sale - Page 1 - Photobucket - Video and Image Hosting
All detail pics can be viewed here.
42.5 lb/hr injectors less than 8 k miles Precision flow matched, but bought in 02. $180
36 LB/HR injectors need to be cleaned. $25
MSD Wires $30 less than 1k miles
Coil pack and amplifier $150 Coils have less than 8k miles, amplifier was bought from O relies put on just to test my other amplifier. Less than 10 min run time. Problem was plug gap too wide, missing above 23 psi.
Scorpion rockere rollers 1.65 ratio. NOT SHAFT STYLE. $100
Bracket for p/s and a/c with delete pully $75
Oil pump parts make offer. Less than 8k miles.
Misc electrical parts make offer.
Speaker adaptors $10 Speakers not included.
PLUS SHIPPING ON ALL ITEMS.
Let me know if you still have these. I could probably stop by and pick up.
Thanks,
Joe
Interested in the roller rockers. What does Not SHAFT STYLE mean excatly? Will they fit the Turbo T/A heads then? If so I would buy them.
You have the shaft style like the factory Gn's came with. The shaft style mount with 3 bolts on pedistals to the head and the rockers fit on the shaft. These are stud mount like you would find on a SBC.
motor
did you get my pm about the shortblock? i wnated to purchase it from you. did you sell it to someone else >
SOLD:
109 short block
Spark plug wires
Rocker Rollers
36 lb/hr injectors
Still have all the rest:
Main accessory bracket with a/c delete pulley
Cam position sensor and drive <---Best offer
TPS sensor <---Best offer
Oil pump gears and some parts <---Best offer
2 Crank sensors <---Best offer
Speaker adaptors
Coil pack with Amplifier, AMP is new.
