Brad Bartilson
- Feb 2, 2002
Having same blowby (blue smoke) condition after installing new short block. Its strong enough to deeply annoy anyone following behind when I'm under load-starting out or going up a hill. I've got breathers on both valve covers. My data says I'm not running rich all the time (would cause "washing down of the oil off the cylinder walls). While I still get the same smoke, the oil is staying clean, unlike my old short block (diry oil was my reason for believing the rings never seated right on my last rebuild). I'll do a compression test, but how do you tell if its a valve guide? Is there a path significant enough to cause this through the PCV/vacuum hose system (to pass high pressure to the crankcase)? I only see them all teed up at the vacuum block atop the throttle body.
-Brad
bartilson@yahoo.com
-Brad
bartilson@yahoo.com
