LAWRENCE ELVOID
- Oct 22, 2001
Can anyone out there give suggestions where to look to solve this problem??
84T-Type runs fair (because I also drive a 86GN) but will suddenly lose electricity and will not even crank. I can put a small charge to it and it will start up and run good again. The problem is intermittant.
The alternator is a one wire hookup from a later year buick. It charges at 14.77V when the engine is running. The battery shows 12.86V engine not running.
84T-Type 20K on rebuilt engine; 86GN DW neck intclr, chip, and large pipes to throttle body; 72 Vega carb turbo and cam; 84T-Type with 87 eng and chip, and more vehicles.
Thanks in advance.
Thanks in advance.
