I keep blowing the 10 amp ECM/SOL fuse that feeds one of the two brake switches followed by the engine compartment solenoids (wastegate, canister, EVRV and AC clutch). When disconnecting the three wire pink/blk pink/blk purple connector from the vacuum release valve on the brake pedal, the fuse holds when turning on the car.
Do I have a short in the purple wire going to the TCC solenoid, is the vacuum release valve/brake switch bad, or could a bad TCC solenoid cause a low resistance to ground and make this fuse pop?
Thanks for your help
