yes thats what you need to run the 1200s.
What your thinking of is the stock gasket, for the smaller ports. the edelbrock intake is designed with a larger port in mind.
you can use the stock type gasket on the edelbrock intake, I would just suggest some port matching be done, or you wasted your time on that intake.
If you do decide to use the 1200s, you WILL need to use that pan as seen in that other thread. it does the same function as the stock type, but its in 3 pieces vs. one. I have in the past used a stock type valley pan gasket and cut the intake sections off, then used 1200s on the ports.
either way, the aftermarket metal pan, is better. It will help the PCV from picking up oil, solved many smoking problems I had by this switch alone.
A.j.
