eastwoodad
- May 23, 2003
Ok...sorry for all this...i've got an N/A 81 regal with the 3.8 and a th-350C and i am new to this forum...so here goes...
1st...i know the ECM controls functions such as primary adjustments on the carb, (whether stock 3.8 or using the 4.1 intake/carb conversion), torque converter lockup, and minor ignition adjustments. my question has to do with the distributor. is there a way i can convert the stock distributor to operate using mechanical/vaccum advance as opposed to by the computer without getting a distributor from a pre-81 car?? will there be any advantage to this??? the reason i ask is i am not totally certain i want to retain the ECM or not.
2nd...can i block off the EGR and will it make a difference (good or bad). if i can, how do i?? is it just removing the valve and plumbing and putting a block off plate on the intake??
3rd...are there any major differences between any of the even fire heads??? which casting numbers are the best?? i have heard through Kenne-Bell that 76-83 heads can only accept valve lifts up to .420 while the 84-87 heads can take up to .460 lift...any thoughts
thanks and sorry for the long post
