Eagle crank and Carillo 6.5 narrow rods
Quicksilver
The crank is new, untouched as shipped from Eagle. $450 b/o
The rods are 6.5", narrow journel, 0.927 bushed pin with 7/16 carr bolts. $500
Shipping not included
Does the crank require special rod and chamfered bearings, or will stock ones work? Why are you selling?
The crank journals mic very close to the used stock crank that I have, so it was intended to use stock brgs, but as with anything new, clearances need to be verified.
I'm selling because I decided to buy a short block that is already balanced an assembled.:D
John
good deal on the eagle crank is it external or internal?
i do not need it but just asking for inquiring minds who may need it.
balancing
All forged cranks that I know of, are intended to be internally balanced. Neutral flexplate and harmonic balancer/hub are needed then weight +-( usually added) to the counter weights. HTH
John
What comp height on the piston do you need for that combo-3.400 stroke with a 6.500 rod?
