E85 -6 feed side fuel system parts & harness for sale...
sakudog
#1
Feed line made of BFG PTFE hose for a stock style fuel pump hat:
-6 stock fuel rail feed fitting -6 level flow (fragola)
-6 feed line from filter to rail w/180 fitting
-6 high flow Earls filter w/stainless element
-6 feed line from hat to filter (has hose adapter for barb fitting at the end made of hose that is E85 compliant)
*You could match this up to any pump on a stock hat.
$200 + shipping
#2
Racetronix double pumper harness, which can easily be modified to use as a nice hot wire kit for just about any fuel pump on the Turbo Buick car.
$45
You could use this for a gas car as well.
Racetronix wire harness!!! Is that for the g7 double pumper do u have a picture or two of the harness
Tony
Talk to me!!! What psi is the Hobbs. How about those pics :)
Guys, the harness is older, it is a good part to re-use for say a hotwire kit with some work. I'm not suggesting using this part in place of buying the right part from Racetronix for a DP setup. You wouldn't save enough to warrant the lack of support.
Think of this as a shortcut for someone that was going to build their own custom setup etc.
It doesn't come w/the hobbs stuff or an additional body ground strap etc. This is just extra stuff I want to get out of my garage. :)
