....need some input regarding a driveability issue. I have done some research on the board and it has helped some. I have an 87 buick that starts to pop and backfire after about 30-40 mins (65-75 mph) of driving. It has an LT1 maf with a gen II setup using #60lb injectors. I've changed the cam sensor with a known good one with the same results. It also will not start if I unplug the maf sensor. If I plug it back in....it will start and really runs fine until I take on the road. However, if I unplug the maf after starting the car, it will cut off and not run. There are no codes and I have had it on powerlogger. Any advice would be appreciated....
