Slotted and dimpled are safe when not turned several times after they warp. Drilled work well, but are prone to fractures and premature failure. Look at big companies that produce high end brakes and you see slotted and dimpled now, far less high end drilled rotors than even 3 years ago. Even brake pad maker EBC does dimpled over drilled for most aplications.
