I have a DP that originally was set up to run both pumps at once.
Can I buy a four wire, replacement wiring harness, retaining clip and sub-harness from a
TB.com vender?
That's been the general idea. I have mounted the hobbs and ran a new wire back to the tank, but it will require me to run a additional wire into the hanger. The original DP was wired so both pumps ran simultaneously.
Thank you gentlemen, I think I will check into a new sub-harness before I try fishing another wire through, or at least look at the hanger again so it's fresh in my mind......
