Got a filter base with 2 in 2 outs on it. [Summit as I recall].
1 of the out ports was used for the engine, the other for turbo feed.[-4 to journal brg turbo]
Plugged 1 of the in ports and hooked the pump out line to the other. [Stage 2/Dutt external pump].
I mounted it behind the pass side headlite. [Oil cooler was put in behind an opening in the air dam.]
