ChrisCairns
Senior Member
- May 24, 2001
For those of you who didn't read my report on Vegas, I couldn't raise the boost over 21.7 psi according to FAST with the new 88 turbo. John Craig suggested that perhaps my acetylene regulator, which I use for a boost controller wouldn't allow more than 15 psi through it.
Last night I removed the acetylene regulator and put 50 psi into the inlet from my regulated air compressor. Exactly 50psi came out (attached to a pressure gauge) with the regulator totally cranked down so it isn't my regulator. (And I was able to cut the pressure to zero by turning the knob all the way up).
Using the single brain cell I have left I thought about the following and would like some input from you smart yet somewhat ugly people....(I wonder if anyone will answer...lol).
Let's assume my turbo compressor is putting out 25 psi into the boost control line. This boost control line is then split, one side going directly to the underside of the Racegate diaphram. The other leg goes into the acetylene regulator and then back to the top of the Racegate diaphram. If I have 25 psi to the bottom trying to lift the diaphram and the same 25 psi (with the acetylene regulator totally cranked down) to the top of the gate then with this boost pressure the diaphram is at a neutral level. The only thing holding the valve in the gate shut is the spring. The valve would only open once the backpressure in the header which is pushing on the valve face equalled the spring pressure.
Does this make sense?
And should I just run the boost line from the acetylene regulator to the top of the diaphram with the bottom port open thereby allowing the spring and whatever pressure I allow through the regulator to control the gate?
Any insight would be appreciated.
