TurboBuickSix
- May 23, 2001
I just put the pump and hotwire kit in from racetronix.Went to start the car after givi giving the key a few on and offs before actually trying it as an attempt to purge the air.When I tried to start the motor it would only run for a few seconds then die.I had about 5 gal of fuel in the tank so decided to go get 5 more for good measure.Still only runs for a second,check fuel pressure,while trying to put on line there is a little leftover pressure in the line that comes out.I also just did the injectors so this fuel was not there from the old pump.No fuel pressure whatsoever.I can hear the pump running.At first(when it did make a little pressure) it seemed to be running slower now it seems to sound as if it is going fast,like maybe it can prime itself to start?? I am dropping the tank back down tomorrow because nothing seems to help.Right at the tank it sounds "bubbly"when running.I will make sure the polarity is not wrong but I am 100 percent sure it is'nt(it made some pressure and the car started for a few seconds).I checked for a pinched line also and the moved freely on the tanks top side.Anyone ever get a bad pump out of the box?? This sucks now I can't even pump all that gas back out.
