EYE-OPENER
- Dec 24, 2011
Had engine built by TEC which is one of the top builders around town (maybe 600 miles on it). I just pulled the plugs to change to the non projected types that has been recent conversations around here. #2 cylinder was black and wet, all oTher cylinders were perfect. I put my scope down in the cylinder and there is a tiny bit of oil on top of the piston which keeps me away from fuel issue and piston/walls looked great. Oil pressure is 80 cold, 18-20 hot idle in gear at 750 rpm. Driving around and idle are really nice. I used cometic gaskets, ferrea valves with new guides and seals (int and exh) white spring style, using 20/50 valvoline racing with zddp. Running an RJC pcv valve with an in,ine seperator getting minimal oil. Here's what I have done so far since findings:
1: checked compression in all cylinders (3 clicks) twice. 145-150-147-150-145-145.
2: checked torque on head.
3. Pulled springs on the cylinder and visually the seals look perfect.
4. Valves have no movement side to side and goes up and down and spin very smoothly.
I am stuck...I am going to put two new seals on just because I'm already there and other than that I'm here asking for help. I don't have a leak down tester but if need be I will get one. Thanks for any help guys!
