87GN&98VET
- Jul 12, 2002
I currently have Eibachs (1" drop) and Bilsteins on all four corners, but I'm planning on adding 4 wheel disks, so I want to lower the car another inch to get the right look. I have two options:
1. Use B-body Bell Tech 2" drop spindles with OE height springs with a higher spring rate. Has anyone ever used B-body drop spindles? If so, what wheel offset is needed?
2. Cut 1" out of my Eibachs and use with OE B-body spindles. Will this require too much shimming to get a 0 camber?
My wheels are 17x8 ROH Snypers with 4.5" of backspacing. I appreciate any advise you could lend....
