cturboaddict
- Apr 7, 2002
I have noticed in replacement of my crankshaft that I had hooked up the crank sensor wrong. I had the three tabs that are attached to the harmonic balancer on the outside of the sensor instead of running through it . The question I had was will this affect the car ( an 85 Regal T-type )?
Also my other question was at about 1/2 throttle I seem to get a stutter under acceleration. And when I set my TPS and I act as if I am accelerating with the lever to watch the voltage rise it gets up to about 3.87 and then all of a sudden it drops to .7 then goes back up to about 4.2 and then ends at 4.6. All the way up to 3.8 is smooth and then bang the skip?????? Does anyone know if this any effect on my problem??? Every TPS that I checked does the same thing.
