billet-boy
- Sep 6, 2008
Ok im new to vacuum pumps, I have just instaled a belt drive pump and would like a little guidence on how much vacuum i should run?
I've just gone rounds with my mechanical pump, I have a Moroso 3 vane pump. If you run more than 10" on a Buick and a duttwieller or stock style pump you will have oil pressure issues. At 15" I had almost no oil pressure. Seal the motor as tight as possible and put the relief valve after the motor on the vacuum pump, NOT ON THE MOTOR. Take the pickup from the front of the VC if possible. These two changes eliminated filling the breather tank every pass and still being able to maintain 10" vacuum. Pay close attention to pulley sizes and pump speed. I ran the car on a chassis dyno to set the relief and crankcase vacuum and check oil pressure under full boost. I would suggest the same. BTW the pump isn't worth much if anything in HP.
Chris, we set our systems up like you said and especially the regulator at the pump. I have almost no oil in the accumulator after many runs.:smile:
I have run my vac up to 14" and not seen any difference in oil pressure? It is a Dut pump and RPM is less than 7000.
It was a big job to get the pulleys sized to keep the pump speed at 1/2 engine RPM.
There is a difference in performance in my car without the pump, about 0.1 sec. and 1-2 MPH.
Chris, I worked with Steve at Star Machine in Baltimore to come up with the right pump and pulleys. We use a cog belt that is driven off the water pump shaft.
He was very adamant about getting the right speed of the pump, and he helped me by providing the proper pulleys.
Took a month or so between the mounting and parts to get it right.
We are building a new web site, and this is one of the items that will be featured with lots of pics. Am now developing a kit for the pump with no AC and no power steering.
The current kit uses the Champion AC delete bracket with another bracket we have made by CNC.
Again from speedtalk, posters there say that with an engine set up with normal rings they see maybe 1-5 hp on a 600-800 hp engine with a vacuum pump. Set up with low tension rings the vacuum pump is worth up to 50-60 hp on an 800-1000 hp engine. I think these are mostly high compression n/a motors, not turbo or nitrous. There is a page on vacuum pumps on Reher-Morrison's web site that I think says about the same thing (which makes sense because Darin Morgan, who was the chief engine builder at r-m, posts on speedtalk ). Even if there is no hp gain, it seems like it would be definitely worth it just to eliminate all the oil drips.
