Booster, brake pedal, master cylinder, vacuum block that goes on top of the throttle body with a port for the vacuum hose, vacuum hose, check valve for the booster and there is also a filter that connects off a short length of vacuum hose after the check valve. Do a search on vacuum brakes and you will find a lot of info that is already on here.
