Running a(custom built 9") "3600"rpm stall in a beefed up 200r4. Also running 373 rear end gear ratio. All I can brake the car up at the line is to 2400rpm before it starts to push, but when I go wot the stall does flash up to 4000rpm.
Does this sound normal? Should I be able to stall it up more off the line?
Also running a new set of nt05r drag radials which are pretty sticky, and new brakes all around.
If anyone has any suggestions to help me get more stall I'd appreciate that as well.
