Connector id.
racerex1
Just finishing up on a total swap from hot air to intercooled on my 87. I have no idea why the p.o went through so much trouble to hot air the car but he did. What a job. Lol Well anyway if you look at the alternator you will see a 3 terminal connector below it. For the life of me I can locate what it goes to. It looks like the tps but it's hooked up. Help. Lol
Air conditioner compressor pressure switch. To clarify the switch is located in the air conditioning lines that cross over to the passenger side of the car.
One of the curved aluminum lines,coming off of the manifold that bolts to the back of the ac compressor,has a fitting to accept a pressure switch. If the pressure switch is there,that connector will plug into it. If not,you need to get a high pressure switch.
No not exactly...still looking for an a/c hose assembly for my car but that's where it goes. I looked up the switch and its a match.
